Discuss Betacom 24 original in the Plumbing Jobs | The Job-board area at PlumbersForums.net
buckley plumb
Does the diverter in this boiler default to hw or heating. Got one today hw works but on htg boiler has no circulation. Suspect diverter - merchant quoted £185 plus vat for diverter
I'd guess heating
how strong is the pump, sometimes pump can be okay on water but not strong enough to get it round the heating circuit
I jumped to deep diagnosis on this one due to pressure of work load. The damn Tennant had shut all rad valves off with s spanner. I now know never to overlook the idiot possibilities
Reply to Betacom 24 original in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath the boiler is difficult with lots of obstacles, is it okay if I run soldered copper over / across the top of the boiler? It'll be about 4" off the top...
