Discuss Biasi Riva Compact HE - Air Pressure Switch in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My Biasi boiler was cutting out, hence no hot water or heating and the fault code was saying faulty air pressure switch.
I replaced the switch and it worked all evening and then cut out again.
If I do a complete shutdown and re-start after a few hours the boiler works again but only for a few hours before same fault.
Fault is still showing faulty air pressure switch.
The fan is starting and running ok.
Any ideas would be much appreciated.
I am a qualified electrical engineer and have no intention of messing with anything gas related but this problem to me seems to be a electrical problem.
All I am trying to find out is if anyone as come across this problem before.
Here we go again , why is it always engineers.
What is you gas safe no , you have not got one . Forum rules , as said above , we will not give out advice on gas appliances
So tell me this, what exactly is this forum about?
Looks like it is a closed shop for so called plumbers who know nothing about plumbing or central heating so ask each other what to do?
Sorry back to work now , cant be bothered replying.
Thread closed as you need to be gas safe to remove the cover see gas safe publication
What a homeowner can do
Reply to Biasi Riva Compact HE - Air Pressure Switch in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
Conditions: nearly 10 year old boiler WB2B, heating mode off, DHW on or also in standby, Boiler shows no fault LED on, no new fault logged, room...
I have an old Modena 80 E combi boiler that is randomly short cycling on windy days. The burner goes out and re-ignites within a few seconds and...
A
Hi, I have Worcester combi boiler which has developed a 'fault' recently. When I switch the heating on, the fire in boiler starts for a second or...
Andy Jackson
A
Hello, I live in a two floor semi with a gravity fed conventional gas fired boiler (Potterton Kingfisher MF). The boiler is fed cold water from...
