Discuss Big house, big job..money no option - What would you choose? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Got a big job coming up. Its a big old house in Chelsea and customer is no holds barred on cost!
Its currently got a Keston C90 light commercial boiler, 2 linked copper cylinders (210l each approx) honeywell wireless programable room stat and 2 channel programmer. heating on one zone.
Im proposing:
Buderus 162/65 boiler
1 x megaflo systemfit indirect unvented cylinders 250l
1 x megaflo solar fit indirect 300l
6 zone system using Honeywell evo home
all pipework lagged with celotex
all pipework saddle clipped
all valves soldered where possible
magna clean filter
spiroVent RV2
What things might you add/manufacturers youd use etc if price no concern?
I would use two boilers combined on a LLH with sequencer switching rather than one large boiler.
Difficult to spec the hot water without knowing more about the hot water demand, and the capacity of the incoming main in terms of pressure and flow.
Whats the lifestyle of the customer? Are they tecno-weenies or digi-tards?
Do they care about energy efficiency, or ultra-convenience?
Lots of variables!
Lots of variables!
Hot Water: 2 baths, 1 with shower
3 en suite showers
8 sinks
2 bidets
All with standard outlets
Family house, 3 kids 3 adults with guests on occasion. basically both baths and at least one shower to run un disturbed.
Incoming mains: 2.5 bar
Flow rate: 22 lpm+
On the techno front I would say they would embrace any new technologies. I would say convienience is more important but they have expressed the future option for solar panels which is why im including the solar cylinder.
Have a look at ACV cylinders. Blisteringly fast recovery times.
Also, if you're going to do the job from scratch, I'd always zone properly rather than electronically. EvoHome is brilliant but I don't like so much reliance on RF communications and battery-powered motor heads!
2 boilers cascaded and run into a LLH. may be a tad more pricey but a really professional job. There's also a backup if one breaks down too so that could be a selling point perhaps?!
162/65 is a little light 162/80 would give more reassurance, purely based on DHW recovery times. Better still cascade boilers as suggested by others.
+1 but depending on how big is big
i would cas two
162/45 if its big
162/65 if its mansion size
low loss header
big pump (adaptive)
28/35 or 35/42 main runs depending of boiler choice
underfloor heating going in?????
Im proposing:
magna clean filter
spiroVent RV2
Megaflo systemfit...who fits those?
I don't know anyone that uses them...much rather do it yourself and lay valves out as and where you want them
And also if its a big house you will probably have a fairly long secondary, if your secondary has got more than 10L volume in the pipework you have to fit an external potable EV anyway, so kind of defeats the object of the bubble top saving space.
Don't forget a suitable water softener that can handle the maximum through put.
There was a slight concern regarding space which is why i suggested the system fit but have scrapped that idea now :)
Exactly right regarding the EV. Client mentioned megaflow so happy to install. Was just gonna chuck in an extra EV anyhow.
Dont think your supposed to use softened water with the GB 162..could be wrong.
not on the boiler on the mains incoming water to the house and cylinder
i would cas two
162/45 if its big
low loss header
big pump (adaptive)
no underfloor heating. Cascading definitely the most professional option but its actually not that big a house. 162/80 might be a better choice with a LLH, 40/80 pump and 28/35 runs
Reply to Big house, big job..money no option - What would you choose? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
