Discuss Biscuit screed between joists in the Water Underfloor Heating Advice area at PlumbersForums.net
mutley racers
Subscribed
Hi all. Hope you are well. I need to quote for a job where they want underfloor heating downstairs in the dining kitchen area. The dining room is screed and insulation. Old screed I have taken up and the old is suspended floor with 100mm joists with sleeper walls 350mm apart.
Anyone use a biscuit screed on these before or have you gone for aluminum plates? Looking for a kind of even heat output between the two rooms with warm up time etc.
Or infill with insulation and ply and batton to top of joists and overlay the lot depending on height ?
No not for me if you infill the joists you can get 12mm or 18mm overlay which would be perfect and you can insulation and vapour barrier below
100mm rockwool
vapour Barrier
Infill joists with 3x2 18mm down from top of joists
Install 18mm ply cut to width of joists fix to 3x2 with glue and screws
Then your concrete ufh panels can go straight across the top with no height build up
Reply to Biscuit screed between joists in the Water Underfloor Heating Advice area at PlumbersForums.net
