Discuss black alkathene pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mjt
HI - me again!!!
At the same property as my previous post there is a leaking compression joint on black plastic to copper connection on a pipe in an outside toilet.
The OD of the black pipe is approx 22mm (21.7mm - 1/2" pipe???) - Would this accept a standard 22mm compression fitting if i were to replace it.??
MJT
I think you need a sort of adaptor but I have seen them done with compression fittings with loads of ptfe tape.
hmmm maybe one of those universal coupler types that philmac do
Reply to black alkathene pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
