Discuss Black walls? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
carl rugman
Hi guys
I have a question which is puzzling me. I have just come back from my parents house and have noticed that they have black sooty walls above their rads. Thay have a worcester heatslave oil boiler. The house doesnt smell of fumes. it is if the rads are full of oil but they are not and they dont leak. Any ideas
Carl
plumbing trainee
Lol. It's because they don't keep the dust under control. It rises in the convection current of the radiator and marks walls.
Dust and muck, sounds bad but see it a lot, sucked up and brushing against wall from convection from rads.
sounds like mould to me is there much moisture in the air? or even dirt lol
It seems to me, that if the blackening is within approx 12"/18" of the radiator tops, and when you wipe with your finger little or no difference ( like wiping dust /just spreads), then its dust....as already suggested.
If its higher up ( the higher , the more likely it may be mould)
you need a gas safe engineer to clean the walls for you :), they are not cheap tho.
I have a pretty powerful steam cleaner that I use to shoot down the rads. Do that a few times a year to clear out the dust and such.
Reply to Black walls? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
