Discuss Blanco 5300 Eye Tap leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
tony9987
Hello, my Blanco 5300 Eye kitchen taps is leaking. I have replaced the cold valve 3 times (so 4 valves in total). After each time I replace the valve, the tap stops leaking for a year, then it starts again. This time, I changed the valve a few weeks ago and already it has slowly started a drip. It must be something else which is failing. I checked the O-rings which are placed after you remove the handle and the cylindrical steel part which covers the ring. Both hot and cold o-rings have a slit in them- is this normal? Even if these were to be failing, I can't see how they would result in a leak from the main tap spout, as the water does not pass through the O-rings before reaching the spout.
Thank you
Hi.
Would you please register with the forum to recieve replies.
When you have, could you pop a picture of the tap and the split in the washer.
Hi, thanks for the response. I registered under 'tony9987' but its still showing as 'guest'. Please let me know if I should do something else. Please see photos below:
https://www.dropbox.com/s/qmbon2iwtkty753/2016-04-07 23.55.36.jpg?dl=0
https://www.dropbox.com/s/oj8ehqzuc8yvlxv/2016-04-07 23.55.59.jpg?dl=0
https://www.dropbox.com/s/e6x4ff8i5vmkwdc/2016-04-07 23.59.14.jpg?dl=0
Thanks!
Please register with us and start a new thread to receive an answer to your question.
Reply to Blanco 5300 Eye Tap leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
