Discuss Boiler Benchmark help please in the Central Heating Forum area at PlumbersForums.net
Last year my boiler broke down prior to which a few radiators were stone cold.
Paid large company who used their contracted installer to fit the boiler after which the radiators still haven’t worked.
On booking the annual service I noticed that the system wasn’t flushed and the hard water section was checked no (even though it's a hard water area).
Company are sending installer to rectify the problem though he is being a bit stroppy about it.
My q is - surely now the warranty is invalid as not fitted as per manufacturers instructions? Also if the problems are rectified, surely more damage to new boiler and system has occurred in one year and am wondering whether to take this further with the company? They seem unbothered and the installer is getting stroppy.
Thank you.
Aslong as the work gets rectified you will be fine your issue is the hard water need a combi mate or water softener fitting
This is what happens when the company subs / only pays there installers 3-400 to fit said boiler
Thanks. Surely some damage has already been done. I am also annoyed that the BM wasn’t filled out correctly. Not concerned about who pays who as not my problem!, job should’ve been done properly in the first place.
Reply to Boiler Benchmark help please in the Central Heating Forum area at PlumbersForums.net
I have a "Firebird Envirogreen Condensing Combi Oil Boiler 26kW" a part has went and I can't find it anywhere, I was at every plumbers merchant...
On my Valliant eco tec boiler the pressure guage is on red when cold . I drain a radiator to correct to pressure and it works fine and stays in...
Oliver1234
O
I currently have a Vaillant ecoTEC Plus 438 system boiler which is 13 years old. I have been having problems with the boiler which potentially...
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was...
Dear All New member here, coming looking for help. A few weeks ago I had work carried out by a British Gas Homecare service technician. It...
