Discuss Boiler coming on by itself in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
redapple
Hi Got a Greenstar FS (Floor Standing) 30CDi. Its programmed to come on in the evening 6-7pm Hot water only. But is now coming on by itself for hot water. It was working fine before no problems. The two valve Honeywell V4043H1056 (272848) which connects to the hot water tank makes a buzzing sound and I believe is the cause of the problem. I was planning on replacing the head . As it opens and closes no problems Before doing this I was wondering if anyone has ever come across this problem and if they found it to be something else? should I be placing the whole valve Thanks
Disagree Howsie, the microswitch inside the valve is live regardless of what state the timer is in. Could be a sticky microswitch inside the valve. Is the valve actually open when its firing itself up? The lever should move freely side to side when the valve is in the open position.
Hi Yes when the valve opens up, lever moves freely. any idea how to unstick the microswitch? someone else told me that it could possibly be the the valve spindle which is stuck?. System is clean, was flushed and inhibited not too long ago and has a filter on it.
You need to test to see if the valve is being powered open or not. This will tell you whether or not it is the valve or other controls at fault.
hi Programmer can open it up and close it , the timer also works. No problem with the other valves on the system. The valve also makes a buzzing sound when in operation(opened)
Depending on age I change the complete valve, it could be the body that is at fault (Sticking)
Perhaps but I can't see a sticky micro switch turning it ON at odd times.
next time its running when it shouldnt be check for 240 on the brown wire if its powered then the fault is elsewhere
Reply to Boiler coming on by itself in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Worcester Greenstar gas boiler circa 2017. There has been a noise coming from the boiler which resembles running water, I have checked...
Hello Yesterday my aqualisa shower sharted making a whirring sound and trickles of water came out of itwhen the boiler came on to heat up the...
Hi, I have a Vailant EcoTec Boiler with a Megaflo. These are controlled by a Honeywell controller. I have one 3 port diverter, where one of the...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer...
