Discuss Boiler failing to respond to thermostat and has to be restarted in the Central Heating Forum area at PlumbersForums.net
stevered
It has become a common occurrence that my boiler is failing to respond when the thermostat kicks in.
I hear an audible click from the heatlink when thermostat is turned up but nothing else happens.
Our heating programmer next to the water cylinder is set to continuous and all looks OK.
The only way to restore central heating is to turn the boiler off, which in turn powers off the heating programmer and pump. Turn it back on and then it fires up.
Worth noting the central heating pump is coming on when the heating is off for long periods of the time now it is cold but I believe that is just the boilers first protection kicking in as it is in the garage so will often drop below 5c.
Any ideas what could be causing this?
Here is my setup;
Vaillant EcoPlus 430
Nest e thermostat and heatlink
Honeywell ST9400A programmer
Grundfos UPS2
Honeywell V4073A1039
I would get rid of the programmer that you don't need, you can get poor connections that cause issues and it's really obsolete isn't it?
Usually these faults are to do with 3port tho.
New head or maybe just new syncro motor will do it. Can check with voltage on orange from 3port - if not 230v when on then that's the issue.
Reply to Boiler failing to respond to thermostat and has to be restarted in the Central Heating Forum area at PlumbersForums.net
It has become a common occurrence that my boiler is failing to respond when the thermostat kicks in. I hear an audible click from the heatlink...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
I have a Glowworm Ultimate 35C boiler. It shuts off at its max temp of 60C when heating radiators and the pump carries on running pumping heat...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
Hi everyone, Just wanted to share my experience with "upgrading" an S plan setup to Opentherm and Vaillant Control Center (VR66). There are a few...
1K
