Discuss Boiler making buzzing noise! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
whitworth77
Hi
I have a Worcester 28i combi boiler. It has started making a whirring/buzzing noise. The pressure keeps climbing slowly too. I keep bleeding the radiators to drop the pressure but the bussing doesn't stop.
I can get a plumber out tomorrow as it is insured, but does anyone know whether the problem could be dangerous?
Thanks!
no more than likely its the fan that is making the noise there should be no safety issues
melted venturi comes to mind which i had on a vaillant fan which i only found out after buying the knew one, worth keeping in mind
Reply to Boiler making buzzing noise! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
