Discuss Boiler 'no flame' cutout with sensible current through flame sensor. in the Central Heating Forum area at PlumbersForums.net
Hi. I have a Chaffoteaux HE 30 which keeps locking out with errors of (mostly) no flame (E04) or (occasionally) flame lift (E18). During the startup cycle a flame is visibly present, and the current through the flame sensor is about 5 - 8 microamps (see pic) until it locks out. Should that not be enough to confirm a flame has been established? The flame sensor itself has recently been replaced, and the burner itself looks fine. Is this likely to be a pcb issue, and is there anything else I could do to test things before paying out for a new one? The problem has been developing over a few weeks. Initially it was only a problem when the boiler was cold, and after a few lockouts it would get its act together and then be fine for the rest of the day. Now its happening all the time!
Needs a gas safe engineer
maybe also due to cost easier to change the boiler depending on factors
Reply to Boiler 'no flame' cutout with sensible current through flame sensor. in the Central Heating Forum area at PlumbersForums.net
I have a customers trianco burner that starts from cold ok for a few minutes (say 3minutes) then locks out then will not stay on. Boiler had not...
Hi I have a BIASI gas boiler as in the pictures. Its worked fine for 12 months. But now, for the last few days, when its first running the bath...
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a...
Morning and thanks for letting me join the group. I'm having a problem with my Intergas 28/24 boiler. The boiler will fire up first time ...
Deleted member 120897
Hi, I have an ideal logic plus combi boiler that has been working fine for all of winter. With the recent storms when the wind speed starts...
3K
