Discuss Boiler Not Switching Off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Im having an issue where my boiler will not switch off even if i turn the heating and/or water off on the control panel in the airing cupboard, the pump still runs and the boiler fires up every now and then. The only way im able to get the boiler and pump to turn off is via the heating & water power switch in the airing cupboard (which goes to the control panel) or the isolator switch next to the boiler in the kitchen.
The Honeywell 3 way diverted value switch has been replaced but didnt remedy the issue, a replacement control panel has been tried to see if that would fix the issue but didnt, if when the heating and water is on i turn down the thermostat in the hallway then the divertor valve switch in the airing cupboard moves over to just water so the thermostate seems to be working also so i think we can rule these 3 things out.
It would seem that the boiler is still getting a live feed from somewhere thus causing it to not turn of the boiler and pump even though the control panel is in the off position, any ideas?
You will need a electrician to test the operation of the 3port valve electrically if it is powerd up when the room thermostat and cylinder stat are satisfied or turned down then that will be the problem . kop
Shouldnt be that much ask when you ring tell them what you need testing not all electricians are good with heating controls is there no one in the family who knows a sparky? Cheers kop
Reply to Boiler Not Switching Off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
