Discuss Bonding present and before and tees, but not within 600mm from meter. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Matt0029
As the title how would people report this on a Cp12? The bondings present, visible and before any tees. However its is not within 600mm of the meter. Thanks.
Supposed to leave a bonding notice informing responsible person. I would note it down in your notes section. Unsafe situations procedure mentions it as does TB102.
Are you not able to move it?
Would need an electrian to join on to the clamp where it is presently and extend I would of thought. Not enough slack for me to move it. Its around 1.5 to 2 meters from the meter.
Not sure it can be extended anymore, I’ve been told by our sparks it has to be a continuous loop. As it has been advised by others it appears to be ok as it’s before any branch :D
Your sparks is misinformed.
Good practice says it should be continuous, but nothing in BS 7671 says it has to be continuous.
Reply to Bonding present and before and tees, but not within 600mm from meter. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
  • Sticky
