Discuss Boss connected to soil pipe at 45 degrees in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi
I'm in process of completing a loft conversion and need some advice on the location of a boss adapter for the shower waste. Can a boss adapter be fixed to a 4" soil pipe at 45 degrees as shown in the pictures? My main concern is that the entry to the soil pipe is on the side and with the pan being higher than the shower waste dirty water from the toilet could go back up the shower waste? I've noticed that the boss adapter says 'top', maybe this is meant to point up and wouldn't work as affectively at 45 degrees. Also, is all grey 4" soil pipe solvent weld? if so I'll replace the orange pipe with grey and glue the boss adapter.
Thanks in advance.
Gavin
Thanks for the reply and advice. I meant to say in my first post - Can I solvent weld the boss adapter to the grey soil pipe, how do I know if it's solvent weld capable?
Reply to Boss connected to soil pipe at 45 degrees in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, We're in the process of upgrading 2 bathrooms in our house: the ensuite and the family bathroom. These adjoin one another. The ensuite is...
Trying to connect up new 40mm waste into the old soil stack (which would be an absolute pain to remove), it's all Osma pipe, from the 70s...
Hi, I have an opening on the 'manifold' (I think that's what its called) on my soil pipe. It appears to be a non-standard size - about 51mm...
Hi all, Have got an old 60/70s PVC soil stack, the Toilet is going into a Hunter branded socket which has an old O-ring design (quite flat with 3...
Morning All, Just after some advice as I have been asked to plumb in a sink and washing machine waste for a new kitchenette. The other side of the...
2K
