Discuss Both outlets from shower pump are hot. in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I have installed a salamander pump for my shower. I primed both sides of the pump before turning and only got hot water even when I turned the the thermostat to cold. Checked I didn't have the feeds round the wrong and was all good. I decided to power the pump hoping the increase in pressure would solve the issue, but no luck. Both of the outlet pipes form the pump are hot, on the inlet I have hot and cold, the out let directly from the pump are hot. I have checked all the obvious thing I can think of.
22mm to both hot and cold reduces to 15 just before the shower valve.
Please help the misses is giving me grief!!
Reply to Both outlets from shower pump are hot. in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
PSxxxxxx
