Discuss brass olive on plastic pipe (22mm reducer) in the USA area at PlumbersForums.net
Hi all, had some great advice on this forum and need a bit more... I've used this reducer (pictured) to step down a 22mm lead loc coupler to 15mm. I inserted 15mm plastic pipe (with a pipe insert) with ptfe wrapped round the olive which is brass. Just read online that that's no good as brass doesn't seal well with plastic pipe is that right? The connection feels solid I gave it a half turn after tightening by hand and it's not leaking. What are the chances of this type of connection blowing off and flooding the house is that likely, and if it was going to leak would it have leaked already? It's been on for several hours now. Would you professionals re-do the connection with copper or leave as it is?
Fine it it’s not leaking and the system is on I would say it’s fine
Would keep an eye on it for the next week but after that your good
I’ve done plenty of plastic pipe with brass olives (compression elbows) and they’ve all been fine. I don’t know where, or who specifically stated, you can’t use it with plastic.
A few sites online and general forum chat saying a copper olive is better with plastic as they are softer and need less tightening. I've got a couple of chrome compression elbows on chrome pipe boxed in too which had brass olives and I connected them to plastic pipe. Nothing has leaked but I'm tempted to switch them out and re-do with copper olives for the peace of mind if it's possible they might leak within the next years.
I am of the copper olive on plastic brigade - although I'm not sure why.
BUT those reducers can leak if you don't use the (invariably brass) olive that comes with them.
In this case as above - obey prime directive - if it ain't broke etc.
There’s an old saying “if it’s ain’t broke, don’t fix it”, which would apply here. You could be opening up a can of worms, or a leak in this case.
Many thanks for the replies and advice, it's much appreciated. I'll take the professional advice in that case and leave them as they are. I'm sure the people in the flat below will let me know if they ever start to leak! Thanks again
Reply to brass olive on plastic pipe (22mm reducer) in the USA area at PlumbersForums.net
T
I have recently moved house and would like to move a radiator from a side wall, to one below the window as is more pleasing to the eye. I...
2K
Hi, I'm installing a water filter which has plastic inlet and outlet fittings like this... The suggested way is to go straight to flexible...
2K
C
Hi there, i’m in the process of remodelling a new build home and have a towel radiator i will be fitting soon to replace an ugly traditional...
1K
I wonder if anyone can help, I've tried several plumbers merchants to no avail. I have removed an old stopcock, (which seized long ago, with a...
2K
Hi, First post here, I have usually been able to answer my questions through searching this forum but now I'm stuck! I have replaced the tiles in...
2K
