Discuss Bristan Mixer Shower Keeps Going Cold in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Bristan mixer shower that keeps going cold, it goes cold for a minute or so and then comes back hot before going cold again. I have replaced the cartridge in the shower and also replaced the shower hose, there was a slight improvement for a week or so but it is now back to what it was like before. I have the same model shower over the bath and there are no problems with that so I assume the problem is with the shower itself. Any advice to help sort this out would be appreciated.
Bazza4465
Hot and cold pipes in the right way ?
Always done it or just started ?
This has only started over the last few months and slowly got worse. The shower is a number of years old and worked okay before, nothing done to the pipework so the hot and cold are in the right way round.
All other taps ok ?
I have the same shower over the bath in the same room and there are no problems with that.
How do I get to the non-return valves and filters to check them, do I have to take the cartridge out?
Thanks for your responses.
If its a bar mixer, the filters will most likely be in the two inlets where the shower is attached to the wall, and probably no non-return valves.
If it's a concealed shower, could be anywhere.
Need to know the type and model.
Just a thought watch what the boiler does when the shower is running if you have other showers that work ok there must be a restriction somewhere
I only know that it is a Bristan shower. Attached is a photo of the shower and one with just the cartridge showing, is this of any help to show me where the non-return valve and filter are.
Sorry about the last post with multiple attachments, I didn't think they were being attached and tried multiple times and posted it before realising.
Reply to Bristan Mixer Shower Keeps Going Cold in the Plumbing Jobs | The Job-board area at PlumbersForums.net
