Discuss Brown gel in CH header in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I recently(3 yrs) had my boiler replaced and the system was really thoroughly cleaned with a professional pressure flush. Fernox inhibitor was used on the refill. Ever since, my header tank has suffered a build up (over 6 months or so) of a thick brown gel which floats on the surface and a brown coating on tank/ball surfaces. I have sucked the tank clear and washed surfaces with bleach and topped up with Fernox on refilling header but it persists. The water in the radiators is clear enough to tempt you to drink it and I never had a suggestion of a problem in the 20 years previous to the recent replacement. My installer is as baffled as myself. Anybody seen anything similar?
Any photos available of this gel in your f&e cistern (header tank)?
I've just cleaned it out unfortunately! Initially it was over half an inch thick but now forms a thinner 'lily pad' kind of formation on the surface; the colour of sh*t to put it crudely. Down below the surface and attached to the ballcock there are thin gelatinous 'fronds'.
So-called bio-films typically contain a mix of fungi, algae and bacteria and can include some nasty surprises such as legionella. As a rule of thumb, take the same PPE precautions you would if you were dealing with human faeces. Use purpose-designed biocide additive as a preventative measure.
Vegetative slime always seems resilient in warm plastic conditions.
( I might be tempted to leave a 10cm off cut of copper pipe in there .. but it may be an old wives tail)
Sound advice. Can you recommend an appropriate additive... one compatible with Fernox?
Reply to Brown gel in CH header in the Plumbing Jobs | The Job-board area at PlumbersForums.net
