Discuss BS 1212 Part 2 Air gap in the Water Regulations area at UKPlumbersForums.co.uk.
Tags:
  1. Readingplumber
    Readingplumber Member
    Hi
    Am unable to find a clear answer to this -
    But the water in the cistern with BS 1212 part 2 float valve what is the highest water category that it can be?
    Im thinking category 3 has in F and E tank not been able to find anything written in WRAS guidebook.
    Can anyone clarify this?
    Thanks!
  2. ShaunCorbs
    Cat 5 if you drill the holes to spec
  3. sammathias
    sammathias Plumber GSR
    Cat 4 I think. Sorry Shaun ;)
  4. ShaunCorbs
    Ab air gap (standard tank spec / layout) if you drill the holes correctly are fine for cat 5 risks
    • Disagree Disagree x 1
  5. Readingplumber
    Hi thanks so far but just normal tank with 1212 part 2 valve With out adding extra weir holes into it.
  6. ShaunCorbs
    Correct only thing overflow must be sized correctly and terminate to outside
    If into stack / waste pipe needs to have an air gap
    Weir holes is an AA air gap
    • Like Like x 1
  7. ShaunCorbs
    What you planning on doing that's cat 5 risk ?
  8. Ric2013
    Ric2013 Plumber
    Rainwater, perhaps? I think that can be cat 5 due to bird faeces?
  9. copperman111
    copperman111 Member
    The rainwater harvesting set ups are generally cat 5 due to potential for bacteria etc so yes you would be correct to assume the pigeon faeces would be a cat 5 risk, therefore a suitable back flow prevention set up would be required to provide the appropriate backflow protection against the risk described suirable AB. AA air gaps etc pipe id
  10. chris watkins
    chris watkins Plumber
    Type AG Type AF
    Top one is an AG air gap which is only good for Cat 3.
    Bottom is an AF air gap and good for up to Cat 4
  11. chris watkins
    The use of a BS1212 part 2 float valve does in its self guarantee the air gap it just helps with the amount of water that can be stored & still maintain the air gap.
    It always down to the Plumber to drill the holes in the right places to achieve this, air gaps are dependant on the size of the inlet & overflow.
  12. chris watkins
    Sorry Shaun but a weir overflow is an AB.
    AA is where inlet is above the cistern overspill & free falls into the cistern. Both however are good for Cat 5 & are the only ones that should be used for a rainwater storage if that is what the OP is doing.
    ref - WRAS book 6.13
  13. Ric2013
    Ric2013 Plumber
    The OP hasn't been on this thread since the 4th July, so we do not know what the OP is doing.
Loading...
Similar Threads - 1212 Part Forum Date
What is this part called? Plumbing Forum Sep 3, 2018
Can you find me a spare part?? Bathrooms, Showers and Wetrooms Aug 31, 2018
