Discuss Building regs part L in the Plumbing Jobs | The Job-board area at PlumbersForums.net
lordyjordy111
Hi again
Just posted about these regs and have just read this
All new systems in dwellings that aren’t open plan must have at least two heating zones, each
controlled by a thermostat and zone valve. In addition, all radiators must have Thermostatic
Radiator Valves (TRVs) fitted except those in rooms with a room thermostat and those in
bathrooms.
does this mean you can't use three ports on new systems???
yes you can use any motorised vavle to control your zones. 3 port should not be used on unvented cylinders.
Hi
@aw heating
thanks for your reply.....
bit confused, how can you use a three port if you now have three different zones ie 2 space heating and one hot water
bearing in mind one port of a three port is an inlet from the boiler???
You could tee off after pump before 3 port and install 2 port. I don't like y plan and much prefer s plan and s plan plus.
You could, but you would still have to fit the two port, as it is part of the unvented's safety features.
Hi
@aw heating
dont forget on a combi you only have two zones soyou could use a 3 port on the two heating zones on the combi i guess, tho ive never done it but it could be done........
Reply to Building regs part L in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
