Hi if fitting a bypass on the primary flow and return to an indirect hot water cylinder I know this needs to be positioned between the pump and zone valves as once the zone valve shuts off the pump will have an over run. Is this correct? Also do people now fit automatic bypasses instead of a gate valve that may have been used in the past.
