Discuss Byretech Shower Rails in the Plumbing Jobs | The Job-board area at PlumbersForums.net
V
Veggie Dave
Just wondering if anyone has any experience of Byretech and/or their stainless steel shower curtain rails?
Reply to Byretech Shower Rails in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes sunk into wall behind bath. Walls have fresh tiles. Have realised as about to fit shower these pipes one is set higher than the other. If you fit a...
