Discuss Calculation help needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
hdp160
Hi... Wavin 22mm Hep20 coiled pipe..... flow 12.5 ltr/minute...(at nominal mains water pressure at inlet) What I need to know is the expected water pressure drop over 50 metres. Many thanks in anticipation ...Nick
BTW I've looked on their websiteam and I can't find it in the technical specifications
if you reference the CIBSE design book, it reckons 22mm @ 12.5l/m (0.2125kg/s) and has a loss of .026 m(hd)/m
Thank you very much Jay.... I make that a 1.3 metre head loss over 50 metres of pipe or about a 0.13 bar pressure drop?
youre ahead of me there mate, I didnt calculate the total because I wasnt sure what the multiplier was for a bend on the loops.
Thanks Jay..... I don't know if my sums are correct either? .. perhaps someone could give thumbs up or down..... BTW no fittings just the total pressure drop over the coil of pipe is what I'm after...
yea mate, assuming I got my maths right then yours is fine :)
Reply to Calculation help needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
