Discuss Can anyone identify this 3 way motorised valve? in the USA area at PlumbersForums.net
as you can see someone has previously removed the cover so I can't find a make or serial number to buy a replacement. Has anyone come across this valve before?? or if its a standard size and most valves should fit with the current pipe work
TIA​
If you're going to change it just go for a honeywell just be aware that compression nuts will probably need changing as honeywell uses a fine thread pitch
Honeywell or Drayton for me
Reply to Can anyone identify this 3 way motorised valve? in the USA area at PlumbersForums.net
