Discuss Can I replace this with a Smart TRV? in the Central Heating Forum area at PlumbersForums.net
Hi guys
I have replaced some of my Drayton TRV’s with the smart Tado TRV’s. However I have this installed in the kitchen radiator, the others I just basically unscrewed and screwed the smarts ones, but this one looks different to the chrome Drayton one (see pix)
My question is can this be replaced as easily as unscrewing and screwing the Tado with one the correct connector or will this require some plumbing?
So its ok to unscrew it? I was afraid incase radiator starts leaking water from there? clearly I don’t have the foggiest how radiators work but ok with replacing the Drayton TRVs
TRV's are principally the same so the head can be dismounted just like the Drayton TRV's, see the vertically knurled band just underneath the TRV head? Give that a turn in the right direction.
Took it off and this is what it is. So looks like it should be fine to replace it with a smart trv
You could try nipping it up but it doesn't look like a permanent leak to me, the gland might've let a little by when you permanently removed the head. Tie a coloured tissue around the base of the TRV and check it on it on a regular basis.
Reply to Can I replace this with a Smart TRV? in the Central Heating Forum area at PlumbersForums.net
Hello, I am trying to identify components in my central heating setup as a precursor to installing a smart thermostat and TRVs (looking at Tado...
1K
Hi All, I thought I'd come to the experts and see if anyone is installing and/or recommending the use of any Smart TRV valves? Particularly in...
2K
Hi. I'm new to this forum and just looking for some advice if someone could please help. I'm trying to fit a Drayton smart heating system and I'm...
I have recently had this radiator fitted and currently it gets very hot. I would like to turn the radiator temperature down however I'm unsure...
I'm looking to upgrade my central heating system with Tado, however my system has two controllers which can fire up the boiler independently and I...
