Discuss Can this kitchen tap be repaired? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi there I have attached a video below, showing where my kitchen tap is leaking from, is this possible to repair by replacing the hose pipe or would I need to replace the whole tap? I had a plumber take a look who said the whole tap needed replacing.
If it is just the hose supply do I disconnect from the mains and pull out from the nozzle? Thanks
  • IMG_0988.mov
    19.8 MB
Problem is do you know the manufacturer?
If yes see if a spare part is available
If no new tap
Reply to Can this kitchen tap be repaired? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
