Discuss Can this thermostatic mixer tap be flipped? pic included in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello
Hoping if someone could help me. My bath tap sadly is hooked up wrong. Botched job by plumbers i hired last year. Can't get them bacl sadly to fix it.
The hot water is running to right tap and cold water to left tap.
It's not much of a problem for 9 months of the year, as i have a thermostatic mixer valve and don't touch it.
But in summer because of the reversed water supply i can't reduce the temperature of the water mix.
For the moment don't want to call in plumbers to reverse the solid copper pipes underneath bath.
So was wondering can the actual thermostatic mixer valve inside the tap be flipped?
So that it works correctly , even if upside down .
fe5Hf5
20170622 060611
20170622 060611
I see.
Sorry no, the internal of the mixer is different on the thermostat and shut off.
I see.
pity thanks. will have to hire a plumber to swap the pipes around.
anyone have any idea how much it costs to cut off copper pipes and then resolder them to correct taps?
broad estimate is fine. just would like a starting idea. In uk London.
Reply to Can this thermostatic mixer tap be flipped? pic included in the Plumbing Jobs | The Job-board area at PlumbersForums.net
