Discuss Can't figure out 1/4 turn tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
flynn230
Alright lads,
Probably a silly question, but how do i get the cartridge out of this 1/4 turn tap? I've taken off the cap and screw but don't know where to go from here. Have tried pulling the lever off the tap but am afraid of breaking it. Have looked at a good few videos but all the taps look different to mine. Pic below. Cheers
Looks like the spline is splitting open differing gaps on each quarter.
May be a new tap, spray some wd40 on spline and maybe try gentle heat on it from a hairdryer.
Yea, I agree it does look like some of the splines are pushed well open.
Maybe try gently tapping a flat screwdriver blade between tap head and each spline to push them towards centre a little to allow head to pull off?
Probably would be easier and as cheap to fit a brand new tap!
it pulls off.
but after you have done all that, looked all over online, gone to the merchant and had no luck finding a valve after 2 weeks, you wish you bought another tap as theres hundreds of the buggers.
and that is if its british!!
it just pulls off or lever in off,maybe a bit of wd on it,it is an ideal standard tap which most plumbers would know,parts quite easy to get
Reply to Can't figure out 1/4 turn tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Forgive my ignorance, with this basic question, but I seem to be struggling to both understand, search for, and source, the appropriate washer...
Hoping someone can help. I have the bath tap as shown in the picture. I need to get the bit that sticks out (little round handle) off. The tap...
Hi all, I have an issue with our shower's hot water. The shower is operated using two separate taps for cold and hot water. When the hot water tap...
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked...
C
Hi I have a sink that has the basin plus another smaller basin next to it, think it is a 1/4 of the size of the main basin. The unit comes up...
