Discuss ceiling fixing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hammers4spanner
Subscribed
Anybody know of any ceiling fixings for use on steel decking also need to use threaded bar with it , cant think of anything off the cuff as need to put some four inch ventilation in for it .
depends on ceiling construction if its concrete you can use red heads which push in annnd the you expand them with a setting tool these take studding in directly
some of the steel shuttering systems have preformed slots that take unistrut wedges best to look what every one else is using once you get to site normally theres a screewfix or similar on route
Its a steel ceiling if it was concrete i would be using redheads and bar but as i said its steel decking and it will be only me that will be hanging anything off it for ventilation, i remember using something ages back on this that wasnt as expensive as unistrut , snowhead has sent the attachment of what i remember
Drill 2 3mm pilot holes in the steel for the screws, and then you could use a munsen ring backplate with M10 threaded rod. Screw this to the steel with self tapping screws, or if you have access to the rear of the steel, bolt it on with 6mm roofing bolts or similar.
.....or drill a hole through the steel wide enough for the M10 rod to go through and put the Munsen ring backplate behind the steel and thread the rod into it.
Reply to ceiling fixing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
There's a leak in the ceiling of my Dad's living room which is on the ground floor and has a bedroom directly above it...
Hi have surplus water feed and return pipes in my home. I can't isolate them so will need to freeze. House built 1970's. They're as far as can...
I'm at the stage of my shower replacement where I have a new shower head to screw into the wall pipes. I tried it, turned on the shower, and find...
Hi, moved into a home a year ago with what is probably an old heating system. There is a gas boiler linking to radiator central heating, and a...
I have a hot water cylinder which has low carbon steel pipework to it - I have tried to add some pictures I need to replace the cylinder because...
