Discuss Central heating sytem water check in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Eyespy999
Hi all,
Can anyone recommend an on site kit for checking sytem water on central heating as I want a quick easy test to check inhibitor levels. I powerflush so will not know what (or if!) there is any inhibitor in the system.
Any help appreciated!
I know some (like sentinel), do on site stuff but it will only test for their own chemicals, unless things have changed in the last few years. Fernox do test kits you send away but they are for proper water analysis.
The old nail in the jar routine was best for that but it was only any use in days gone by when people had time and patience.
I have a TDS meter, any idea what readings I need to be looking at to guage inhibitor value? Thanks
The Fernox TDS meter, for example, is described here:
TDS Meter (Total dissolved solids meter) | Fernox
Costs about ÂŁ100 and comes with instructions. It's not really for measuring inhibitor concentration, however, it's designed for confirming that the system is clean after flushing.
For comparison, ÂŁ100 is roughly what a lab analysis of one or two samples containing unknown amounts of inhibitor of unknown brands will cost.
Reply to Central heating sytem water check in the Plumbing Jobs | The Job-board area at PlumbersForums.net
During an install of new boiler ('old' boiler died after 11-12 years) the system was "drained" but I guess maybe 90% of water was left in the (rather large) underfloor pipe system. What is the best way to tell how much inhibitor should be added in this case? (also taking account that system was...
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and plasterboard celling. I have got unvented pressurized RM Cylinders hot water system with 27KW Worchester gas boiler with expansion vessels . When...
losing pressure
L
So a strange conundrum regarding water temp if anyone can help resolve, would be much appreciated. Ive tried to give as much info as possible to give a full picture but let me know if ive missed anything. I have a Baxi Avanta 25h heat only boiler. Works fine. Unvented 300ltr megaflow. Stated...
Can central heating / gas engineer expert help me with below issue. During winter time only, I have been having issue with low pressure or pressure dropping with unvented hot water cylinder system. During summer time there is no usage of central heating so the pressure at unvented system is not...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always amazed at the water pressure so on the odd occasion that the water was only luke warm it was easily forgiven, but over time we have come to realise that...
