Discuss CH only works when HW on (no HW off on programmer) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi - first post here
Trying to resolve an issue with our system at the moment. We have a Potterton Suprima boiler with a Sunvic 207 XLS programmer. I’m only able to get CH to work when HW is active. There is no HW off wiring into the programmer which I imagine could be the issue after doing some research.
However, something that confuses me... when I send a call for CH only this activates the micro switch in the three port valve and turns the spindle. So far so good.... but it doesn’t fire up the boiler.
Just wondered if this would be a wiring issue (due to not having a HW off lead on the programmer) or whether this could be a physical issue with the valve itself.
I’m a total novice but have been studying the Y-Plan and looking at our setup for a number of hours! I imagine a HW off wire could solve the problem but obviously it’s a big job running wires from the wiring unit in the airing cupboard upstairs to the programmer next to the boiler.
I’m about to get a Nest installed so wanted to resolve this before going ahead with that if I could. Would a Nest make any difference to the issue I have if I were to go ahead with the current way of working (having to put HW on when I want CH)
Any advice or thoughts welcomed.
Many thanks
Could be a port valve issue eg not moving all the way to heating so the micro switch isn't contacted
I would start testing you any good at elec fault finding ?
Check on the back of the clock. Is the top dips witch set to gravity. If it is you could have had an old gravity system at some point and whoever installed the suprima set it up like this to save running a new cable
Reply to CH only works when HW on (no HW off on programmer) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, Hope somebody can help :) I have a vented HW system with a pressurised Ch system but got bit of a annoying issue, when the hot water...
Hello. I've just replaced our old Potterton EP2 CH controller with a Drayton Wiser HubR (& peripherals). The old backing plate wasn't...
I've just noticed that with the CH programmer either selected off or timed off, the CH can still be controlled on/off at the room thermostat. HW...
Hi, would appreciate any thoughts on the below. I have an almost 10yr old Ferroli Modena 32S HE system boiler. (I am aware of their reputation...
I have a problem where my HW heats only when my CH is not on. When both are on only CH works. I have insurance for the boiler and heating, but not...
Deleted member 120897
