Discuss Change plastic insert for screw in in the USA area at PlumbersForums.net
Is it possible to change this plastic insert for a screw in style fitting or would it require a new tap?
I would like to be able to just to change the fitting as it is a rental property so cannot/don't want to change the tap. I would like to change for a screw in fitting so I can have one of those slide in shower adapters as I don't like them rubber slide on ones.
Thanks in advance
need to change the tap and really tbh the shower should be thermostatic as its a rental
Reply to Change plastic insert for screw in in the USA area at PlumbersForums.net
I have a plumber coming tomorrow to change a cartridge on a badly dripping tap on my bathroom mixer unit. There is no separate isolating valve for...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
