Discuss Changing 2 zone heating back to a single thermostat? in the Plumbing Zone area at PlumbersForums.net
We bought a new build a few years ago which I think at the time regulation said heating must be in 2 zones which I believe is no longer the case. It’s a small property 3 bed semi and has a very open plan design so it really didn’t need it. On top of that the stat in the mater bedroom upstairs also controls the down stairs kitchen, hall and bathroom. The kitchen is off the lounge and again open so when heat rises and switches off the room stat kitchen is freezing .... anyway there’s 2 2 way valves in the cupboard upstairs and combi boiler is down in the kitchen. Is it easy enough to just have the 1 stat which is centrally located on the bottom of our stairs control both zone valves to essentially make the system work as a single zone?
2 zone regs still apply today probably when your house was built it was relatively a new reg but yes it is easy to configure it to be controlled of one stat
Ah ok I read somewhere it was changed back in 2015 which is when it house was built. It seems a daft idea in a reasonable sized semi specially when the upstairs stat/zone feeds downstairs rads. Having a nest stat installed tomorrow so going to have it in the central location at our stairs / lounge where one of the stars are and have that control the lot. The stat in our bedroom is behind the door as well which probably doesn’t help.
I take it a wire would just run off the first valve to Ho pen the 2nd at the same time so heats going to all rads?
Reply to Changing 2 zone heating back to a single thermostat? in the Plumbing Zone area at PlumbersForums.net
A bit of clarification - I have extended a 3 bedroom semi detached and at the time central heating pipes were going in I told the plumber could I have 2 zones - one for bedrooms upstairs and another for the living areas downstairs. Now the plastering has been finished and I am costing the combi...
Afternoon Fellas If anyone has time to help with this snag it'd be much appreciated. We have a wet-floor system controlled by John Guest UH3 and rather dated Heatmiser DT thermostats. One of the upstairs zones is combined for the bedroom/dressing room. So that's 2 rooms, 2 manifolds, but one...
Hi. A new house regulation for a 2 zone heating system because it's bigger that 150sqm. I'm I right in saying zone 1 should be all of the downstairs radiators and zone 2 all of the upstairs radiators ? I have thermostat room programmer down the stairs and another one upstairs. I think the two...
2K
I have an older gas boiler HW heating system with a taco circulator pump for each zone that worked fine last season. When turning it on for the 1st time this season I found a problem with the boiler not running on one of the zones. If I turn on the heat to zone 1 I hear the system...
HI folks, this post is a follow up to my post relating to my single pipe heating system. In summary, I have a house built in 1980 (I bought it 2 years ago) that had a single pipe heating system but over the years there have been some changes made to the system that meant it didn't work. I have...
