Discuss Changing a broken TRV in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi folks,
I have a combi boiler.
The trv for one of the rads needs changing.
Do i follow these steps:
Shut boiler
Make sure the lockshield side is closed
Slowly undo trv radiator nut and drain water from radiator.
Change TRV
Pressurise the system.
Please advise.
Turn boiler off electrically
Drain radiator system by a drain off
Drain the rad with the faulty trv on
Replace trv
Refill and new inhibitor
Turn boiler back on electrically
Replace trv
Thanks, Shaun.
My lockshield was leaking a month or so ago. An engineer followed the above but he did not drain the system. He just undid the lockshield nut and let the water drain out of the Radiator. Then changed the lockshield.
But because its the TRV i must drain the entire system?
He must of took the pressure off first
It is possible to change the Trv like for like by just taking the pressure off the system , you need a container and wet vac and the theory is you are trying to pull a vacuum on the pipe if air can't get in the water won't come out isolate both valves drain out the rad, open the trv until flow slows to a manageable amount or stops work quickly because it not always a successful if that air gets in . Kop
Reply to Changing a broken TRV in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
