Discuss Changing Danfoss HPA2 for Honeywell in the DIY Plumbing Forum area at PlumbersForums.net
I have a Danfoss 2-port valve model HPA2 (which has suspect motor issue)
I can get Honeywell 2-port valves & motors much cheaper & easier as local Trade place stocks Honeywell.
Is there a direct equivalent Honeywell motor activator? ....... so I could just swap the synchronous motor over ? or would I need to swap the whole valve ?
Trade counter said there is also a generic synchronous motor that fits either ? .... they any good ?
Ideally, I would obtain Honeywell complete valve, but just swap over the motor now ..... and change valve later when the system can be drained down.
Reply to Changing Danfoss HPA2 for Honeywell in the DIY Plumbing Forum area at PlumbersForums.net
Is there any advice on using Honeywell Evohome with 2 zone heating. Honeywell support are pretty useless and give conflicting advice. They suggested I ask my installer (but my installer suggested I ask Honeywell). I found a support article on the Honeywell Resideo website by Googling...
2K
Hi I have changed my Honeywell T6360 thermostat to a Salus T105RF wireless thermostat. There was three wires going to the original honeywell thermostat. One of these being the supply and another going to the boiler. I wasn't sure what the other wire was and so didn't connect up. Now the Salus...
Deleted member 120897
Hi, I have 3 port value for HW & CH. Loft extension added many years ago so they added a T to go upstairs, only 2 rads up but 11 downstairs covering at leave twice the floor area As per diagram has free flow Up or Down, no way to balance. Works pretty well but last few Rads (in kitchen) are...
Hi, My combi-boiler has just given up heating the house and basically only delivers hot water. While in central heating mode it heats up and stops to prevent overheating of the internal section of system. No fault or error code are displayed. Suspicion: 3-way changeover valve assy. So I...
When either of the 2 port motorised valves closes, I get a loud clunk. A Honeywell automatic bypass valve was fitted a year or so back to replace a gate valve bypass. I'm happy its in the correct position & orientation, Its set to 0.2 bar. I don't believe we had this clunk last year. I suspect...
2K
