Discuss Changing push fit boss to solvent weld in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I'm currently DIYing my bathroom and have a soil stack with 3 waste pipes bossed into it (bath, basin and bidet) - all waste is currently push fit under the floors.
Before I tile the floor, I'm going to replace all the push fit waste with solvent weld - it's not leaking but seems prudent as it isn't well supported so will need attention anyway. I'm getting rid of the bidet so will purchase a push fit blanking plug to blank that boss off.
Question is - how would I easily change the remaining 2 push fit bosses to solvent weld? From what I've googled, it's likely the bosses are solvent welded onto the soil pipe so not sure how to remove without damage. I cant "just have a go" without a plan as the soil pipe has the other toilet connected to it further up so don't want to bugger it up! I appreciate I can connect the new solvent weld waste to the old push-fit via a compression fitting, but that seems like an extra joint for no reason?
Thanks.
Any chance of a picture of the push fit adapter if it’s the type I’m thinking of no
Reply to Changing push fit boss to solvent weld in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes sunk into wall behind bath. Walls have fresh tiles. Have realised as about to fit shower these pipes one is set higher than the other. If you fit a...
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the depth of my cupboard is larger than this. The issue, however, is that the waste pipe which leads from the sink (next door cupboard) comes out quite a...
