Discuss Chrome Drain Valve in the USA area at PlumbersForums.net
Hi, I am currently fitting a designer radiator in my kitchen. The vertical pipes will be channelled into the wall and connect to the rad valves horizontally but I am considering teeing off one of the vertical pipes and fitting a decorative/chrome plated drain off valve, just above the skirting board level. I appreciate it may look rather odd but this is the most convenient location for a drain off valve. Does anyone have suggestions for a neater solution? Thanks
Can you fit a lockshield drain off to one of the rads ?
How about one of these ??
Reply to Chrome Drain Valve in the USA area at PlumbersForums.net
