Discuss CO2 alarm installation in the Gas Engineers Forum area at PlumbersForums.net
Matt0029
Do you tend to go with the regulations in the gas safe books when installing these. Or the individual manufacturers instructions they all seem different
I wouldn’t know as I’ve never installed a CO2 (Carbon Dioxide) alarm 😂. Assume you mean CO (Carbon Monoxide), Moving on, I tend to go with the mi’s, can’t see them being that different as they should be following the British Standard.
Useful recommendations with reference to the British Standard's advice towards the bottom of this page:
In essence it says put the thing somewhere that air from the source is going to circulate and away from sources of heat/steam that might damage it.
More the 1/3 meters that is more critical? Though I have seen just put on top of the boiler
I follow mi’s, which we fit Aico and they state 1m minimum 3m maximum. If it’s on top of a boiler or on top of a cupboard then that’s the installer being lazy. I’ve also seen mains ones directly above a cooker 🤦🏻‍♂️
Reply to CO2 alarm installation in the Gas Engineers Forum area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
Hi all I need to run this CH pipework to a radiator located beyond the electric wiring in the image below. Just to be safe I was wondering if there are any rules / distances, etc I need to be following when avoiding the wiring? Many thanks. P
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes sunk into wall behind bath. Walls have fresh tiles. Have realised as about to fit shower these pipes one is set higher than the other. If you fit a...
