Discuss coach screws problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
MikeF00
Hi, i'm in the middle of installing a wall hung toilet frame. Unfortunately, the walls in my house aren't great, and the 2 large coach bolts that fasten the frame to the wall aren't gripping the breeze block very well. Im using the raw plug and coach screws that came with the frame. They are big screws because i guess they must support quite a load.
Any suggestions?
2 part epoxy resin plug mix, inject into hole and then insert thread, let it go off and nuts and washers to finish off
i doubt those blocks will hold a lateral load like someones bum as well as the loo from 2 points?
i would be looking to fix a sturdy batten across the span at 4 points then plasterboard over then fasten to that!.
or get another type of toilet. I would only look to use a wall hung pan if the walls were proper bo, i tell the.
Reply to coach screws problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I'm a homeowner, not a DIYer. I have an almost 1 year old SaniCompact Comfort wall-hung toilet which has worked flawlessly until about a...
My step-daughter bought a 50's end-terraced house at the start of the year, and found there was a leak from Mira bar shower that was coming...
2K
Hi, First post (be gentle!) I joined looking for advice and hope someone can help! I’m looking to get a wall hung toilet but have a couple of...
3K
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
Hi All I have recently purchased a Grohe WC frame for a wall hung toilet. Can anyone tell me if it is OK to use the bolts that came with it to...
5K
