dontknowitall
So is this thread finally over....
Aachhoooooo!!!
Oops, excuse me!
Discuss cold rad in the Plumbing Jobs | The Job-board area at PlumbersForums.net
why?....bump :waving:
... its the summer
Not round here it ain't!
I have 1 cold rad in a downstairs cloakroom.
I have flushed it, tested the valves ( not trv ) and connected a hose from the o/side tap to each valve to blast any air-locks.
I have turned off all other rads and it still won't work.
I have replaced rad with a length of 15mm pipe and the pipe gets hot immediately! Put a new rad back on and it works for 2/3 days then fails.
If I draw 1/2 a bucket from the return pipe, hot water is drawn thru the flow pipe and the rad works for 2/3 days.
I know it could be a blockage, either air or sludge, but how come I can always draw hot water thru if I drain from the return pipe?
It seems as if there is something stopping the free flow thru the system which I can by-pass by encouraging the flow when draining.
I would be interested in advice as to what should be my next step.
Someone must have come across this before!!
Can you not fit wireless radiator valves? Surely that would do the trick.
Reply to cold rad in the Plumbing Jobs | The Job-board area at PlumbersForums.net
