Discuss Cold rads in the Plumbing Jobs | The Job-board area at PlumbersForums.net
stratplus
Hall rad and kitchen rad back to back stone cold. Upstairs all hot, another 3 downstairs ok. Turned all upstairs rads off still the same two cold. Turned off the good 3 downstairs then boiler goes off.
Turned off cold rad at lockshields x2 and crack the nut, full bowl under and vaguely luke warm. Re-open rads and still sone cold.
Any ideas?
Yep you have a blockage on that leg that feeds the back to back rads which is why the boilet knocks off ss it overjeats cos theres no circulation. If it was air it would have cleared.
Microbore by amy chance? Manifold blocked port?
15mm plastic to copper tails.
Brand new system, new build. Water pressure to the rad is fine.
Possibility of piping wrong? Last rads on the run, pipe two flows/ two returns into the same rad?
Another one, an air source heat pump not working. Flow outside on heat pump gets hot on the flexi connection but the copper pipe atrached to it is cold ie no circulation. I reckon primary flow and return are crossed in a/c. Same site.
Reply to Cold rads in the Plumbing Jobs | The Job-board area at PlumbersForums.net
