Discuss Cold water tank subsiding when heating is on in the Plumbing Jobs | The Job-board area at PlumbersForums.net
U
Unregistered
Hope someone can help.
We had problems with our boiler -gurgling and water sounds. Plumber came and replaced pump - he said however that pipes still struggling due to blockage in u bend which must be sorted. He said however will be fine for few weeks. Boiler still not great but working just but strangely when heating is on the water level in the big cold tank in the loft subsides whilst being refilled via ball valve. Is this usual - we are away for a couple of weeks and I am worried we will return to a new water feature in the house ! Many thanks.
Please register with us and start a new thread to receive an answer to your question.
Reply to Cold water tank subsiding when heating is on in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, We moved into a new property yesterday and are a little baffled by the heating/water tank situation. The previous owners unhelpfully left any kind of instructions/manual and therefore trying to figure out ourselves. We have what looks like a boiler/water tank system (coming from a standard...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always amazed at the water pressure so on the odd occasion that the water was only luke warm it was easily forgiven, but over time we have come to realise that...
Issue with boiler short cycling in system with hot water tank. We have an ideal heating logic heat2 h15 boiler which feeds a hot water tank upstairs in the house. We have an issue where if the boiler isn’t set to 80c then the boiler will short cycle, the hot water tank thermostat is set at...
1K
I live in an apartment and have a cold water tank in it. The cold water tank feeds the cold water tap in the sink and the bath. Recently, I refurbished my bathroom and, according to the plumber that fitted the new taps, high-pressure taps were fitted. Consequently, the water that comes out of...
1K
First post as I can not figure this one out. I have a hot water boiler heating system, gas fired, with an HTP SuperStor indirect hot water tank. I'm on well water and have a water softener and two whole house filters for my water. Three days ago I found my high pressure relief valve tripped...
