Discuss combined toilet bidet back flow prevention in the USA area at PlumbersForums.net
customer would like combined toilet bidet fitted, spray is fitted to the pan, not hand held hose, she has unvented system.
does anyone know what back flow prevention can be used ?
are check valves on supplies to the mixing valve sufficient ?
wras advice seems unclear for unvented systems.
thanks in advance for any suggestions or advice.
1. As rpm says, separate tanks for hot and cold with air gaps for backflow prevention.
2. Check valves are not adequate safeguard against Category 5 fluid back flow / back syphonage protection.
Cat 5 risk so break tank with weir and pump also 15l unvented so it’s not just cold water
As you've been told, seperate supply to bidet seat from a tank with an airgap. There are no mechanical backflow prevention devices for Cat. 5 water.
Reply to combined toilet bidet back flow prevention in the USA area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
