Discuss Common duct for gas and electric in the Gas Engineers Forum area at PlumbersForums.net
Just a quick question on common ducts for gas laundry appliances. I have recently looked at a gas ironer which shared a common duct with 2 electric dryers. I believe this isn't allowed but the manufacturer sais it's up to a risk assessment. Any ideas anyone.
Are all appliances just using this duct for flue extraction and not air intake as well ?
Air intake is via exterior door grills and plentiful so ventilation is fine. These are open flued appliances. I don't believe different fuel types can share a common flue(exhaust duct) but saying that, I don't think different appliances can share either. The ironer has no dampener so even if it was all gas then I don't think it would be safe. Anyway I'm hoping to hear more from the manufacturers soon.
All depends on the manufacturer and the common flue designer to see if it can take moist air and doesn’t start to fill the duct up with water eg condensing and it should have a nrv etc
Reply to Common duct for gas and electric in the Gas Engineers Forum area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
