Discuss Communal / District Heating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
GSS
Hi Guys
Im after some expertise from plumbers who work on new housing blocks fed from a communal boiler
The issues I am coming across relates to air locks that stops flow through unvented hot water cylinders and underfloor heating
Need to discuss design issues within the property and possible solutions
Regards
Keith
sounds like its pulling air in for somewhere or no inhibitor
Pulling air or ye have a slight leak. That or maybe pressurisation unit in main boilerhouse set up wrong/or seized.
Doesn't sound like a DIY fix there. I think you'll be getting a decent plumber in GSS to have a look
The district heating is pushing a lot of air / dirt around the system
Id like to talk to someone who has experience with design layout within the flats as it seem that most flats are working off the immersion backup and not communal heating.
the layout is
Flow enters flat with iso valve, then PRV to 3 bar
It then goes via
2 port zone to unvented cylinder
2 port zone to towel rails
Underfloor heating pump
Although supply is good, 80 deg its not circulating through the cylinder, towel rails and in some flat the UFH is not circulating
the only AAV is on the UFH manifold
Want some help to identify where the air lock would most likely be and where to place additional AAV to resolve
Well I think at this stage your gonna have to cough up and have someone to come out and view the site. This is a bit bigger than a drippy tap advice question
Can't really discuss a specific job such as this without actually seeing it if you're going to carry out any alterations etc.
Best of luck GSS
Im new to district heating
But it seems to me that the return pressure is equal or less than the flow, hence no flow around system
On the incoming flow and returns are two PRV that can be set between 1.5 and 5 bar
Should the flow PRV be set hight than return or lower
The boiler house feeds three blocks, maybe 300 flats in total
I have tried going back to the installers but they have washed hands as over three years old
Also noticed that no bypass on the down stream of PRV, that means that if both 2 port valves are shut and heating off then its a dead end. is that right!!!
I dont know hence after someone with experience of this type of installation who can offer some technical solutions
I suspect that someone will have a design spec for similay set up?
Reply to Communal / District Heating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem...
So a strange conundrum regarding water temp if anyone can help resolve, would be much appreciated. Ive tried to give as much info as possible to...
Context for issue: Last winter the temperature switch on my boiler shorted somehow, the boiler was then running WAY too hot and ended up...
C
Hi, I'm English and live in the Czech Republic and I'm having difficulty with my heating system. Unfortunately, I cant find any heating engineer...
