Discuss Compression fitting advice in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello,
I'm considering fitting an isolator valve to 15mm feed to my toliet cistern. It would require cutting off an existing compression fitting for a flex hose, after which I'd only be left with maybe an inch and a half of pipe.
I've never fitted a compression fitting before, can someone please advise if I have enough room here to fit a new compression fitting?
Thank you,
Bill.
Or get a flexi with a valve in it eg
https://www.NoLinkingToThis/p/flexible-tap-connector-with-valve-15mm-x-1-2-x-300mm/3558g
Yes fine to re use
You can put some joint compound but tbh you should be fine
Reply to Compression fitting advice in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
