  1. Hi, welcome to the new look UKPlumbersForums.co.uk - Login with your usual login details, or sign up if you don't already have an account. If you post just once, all the advertisements get automatically removed. We have some competitions coming soon, and lots of new feaures.
Discuss Condensate pipe terminates into neighbours gutter, is this ok? in the Central Heating Forum area at UKPlumbersForums.co.uk.
  1. ShaunCorbs
    ShaunCorbs Trusted Plumber GSR Top Contributor!!
    that make no sense, so you would bond the sink top, baths , rads in bathrooms etc
  2. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    No mate. Something BG hammered into me. I would test for bonding and if there was not any I would instruct the customer that they need it doing at the gas meter. At least then the boiler would be bonded.
  3. goz666
    goz666 GSR
    We bond the five pipes under the boiler, it came about years ago during a Corgi inspection and the Inspector asked us why the boiler hadn't been bonded across the pipework when it was in a kitchen almost the same as the one in the pic, we explained that it wasn't something we did and he said from now on in areas of high humidity I want to see the boiler pipework bonded. Done it ever since, right or wrong we still do it.
  4. Darren Jackson
    Darren Jackson Plumber GSR
    We don't cross bond anymore 17th threw that one out. Main ecopotential only and a must.
    • Agree Agree x 4
    • Like Like x 2
  5. ShaunCorbs
    as they used to charge more for it at the boiler and then charge for the main :)
    • Agree Agree x 1
    • Funny Funny x 1
  6. ShaunCorbs
    did you ask him why ????? elec regs dont require it or gas regs
  7. goz666
    goz666 GSR
    Nah Mate just did it, must admit though in this area most boilers we go to have been bonded across flow, dhw, gas, cold and return. A mate of mine was ranting the other week that all this bonding should be done by leccys. He still bonds the pipework as most lads seem to round here.
  8. Harvest Fields
    Very very true. I am not bothered about bonding at appliance as long as it is there elsewhere. But on all my installs I check they have it and if not I get them to get a sparky to do it for them. Ie at the meter or cold water pipework
  9. ShaunCorbs
    and these days you have rcd which require them to be bonded if its an old 3036 its ncs anyway
    • Informative Informative x 1
  10. king of pipes
    king of pipes Trusted Plumber GSR Top Contributor!!
    All the guys have coverd everything but i must say it is a very poor install for the money you paid you should have got a better quality boiler and tidyer job than that hope it gets sorted regards kop
    • Agree Agree x 1
  11. cr0ft
    cr0ft Trusted Plumber GSR
    Just to clear up the bonding issue (as an electrician), if the power supply to the boiler is RCD protected then no cross bonding is required. All of the pipes coming into the boiler are attached to the boiler case which is earthed back through the earth busbar on the consumer unit. No point in adding work for the sake of it!
    • Agree Agree x 3
    • Disagree Disagree x 3
    • Like Like x 2
  12. Fiona
    Fiona New Member
    Thanks so much for all your feedback!
    We had him in this morning and everything that was raised has been seen to. But just to clarify for those wondering, yes the benchmark was completed in full in which it was stated the system had been flushed. We have also since received the GSR certificate for the job but I have also requested an inspection so hopefully we have someone in soonish to ok it all.
    Strangely though I ended up contacting an expert via ciphe.org.uk and received the following -
    "it is ok to discharge the condense into that rainwater guttering provided the owner of that guttering agrees". Obviously they weren't happy with it hence the looking into this in the first place but its interesting to see it being ok after all that has been said.
    Anyway, hopefully its all resolved now and we have happy neighbours again.
    Thanks for your help!
    Fiona
  13. scott_d
    scott_d Plumber GSR
    It can only go to rain water if neutralised or it's a combined rain water and sewage drain.
    Was the filling loop connected to the hot water?
  14. leesparkykent
    leesparkykent S. Mod
    The only place boiler pipework needs bonding is if its installed in a bathroom that's been wired to pre 17th edition (so no RCD on bathroom circuits) as all extraneous conductive parts and exposed conductive parts in that location require cross bonding so in the event of a fault the extraneous and exposed conductive parts are at the same potential.
  15. magicno1
    magicno1 GSR
    Double check valve installed wrong! Should be on the cold inlet guys!
    Sorry to say but Rouge Traders may like this one!
Loading...
Similar Threads - Condensate pipe terminates Forum Date
External condensate pipe refused permission - help! Central Heating Forum Jan 10, 2017
internal condensate pipe Central Heating Forum Dec 28, 2016
Ac condensate drain pipe Fittings & Pipes Oct 8, 2016
Potterton Precision Condensate Pipe Central Heating Forum Sep 29, 2016
Boiler Condensate Pipe Plumbing Forum Apr 15, 2016
condensate, overflow pipe brittle? Plumbing Forum Jan 29, 2016
condensate pipe chased.in to wall Plumbing Forum Jan 12, 2016
