Discuss Condensation and mould in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi
I am having problems in the bathroom with condensation when/after taking a shower which is causing mould.
I believe I need an extra fan to be fitted through the wall with shutter (to prevent cold air coming back in) and run on timer.
1. Should the above be sufficient or is there anything else I need to take into account?
2. Can a plumber fit these or does it need to be an electrician?
3. Are there any brands/types that are recommendable?
4. Any to avoid?
Whilst looking for fans I noticed that there are some that are always on low to extract humidity regardless of whether from shower or not as they adjust their speed.
5. Are these a good idea?
6. I presume that as always on that cold air can get in from outside all the time (no shutters)?
Sorry for the long query but as elderly I would like to get this right and not have something installed that will need to be changed later
Do you have a window in the bathroom?
I would get an electrician to do it.
In terms of which type you get is probably a discussion to be had with the electrician. You can get them on separate switches/on with the lights/ or either of them with timed over run (recommended)/ or humid stats.
Depending on how humid/ how much ventilation your house has/ how much and how hot you use the shower will depend on which to go for.
Personally if you can put an inline fan in the loft venting out the soffit would be my choice. More powerful and quieter. I would also have it on the light switch with a timer as I wouldn't trust my family to actually turn it on if it was switched separately.
Most fans have non return valves built in but speak to the electrician
The absolute key points of having extractor fans added in bathrooms are:
1. a suitable air gap under the door to ensure sufficient airflow into the room
2. the fan must have an over run timer of at least 10 - 15 minutes
3. the fan air through put needs to be high
4. if the fan doesn’t go straight out of a wall, the pipe work in the loft needs to be short AND if long don’t use flexible pipes
If pipe work needs to be long, that is ok but you then need a centrifugal fan not an axial one.
There are now some pretty good “mixed flow” fans that perform very well.
I had a similar problem in a bungalow I Lived in. In line with current building regulations I installed a continuously running fan to circulates the air 24/7 at a very low rate. The fan I selected was fitted with a humidistat that boosted the fan to a higher speed when necessary. Installing this one fan, not only cured the condensation in the bathroom but also reduced the moisture level throughout the bungalow and resolved the mould issues in other rooms. Because of the moisture levels on the rest of the property the fan ran for about three months before dropping to the slow speed
Thanks, will bring it up when the electricians come to quote
Reply to Condensation and mould in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi all, We recently had a ground floor bathroom/wet room finished off, It's about 3.6m long by 2.7m wide, tiled from floor to ceiling and has no...
5K
B
Hi everyone, I have a Santon Premier Plus PP120E (unvented direct immersion heater) fitted with two thermostats, which provides hot water to taps...
Bridog
B
Hi I need some advice as this has been ongoing since august and nobody can find a problem but meantime water is damaging my walls. The lady...
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
We live in a 1980s four-bedroom detached house. The time has come for new central heating. The current system is a mild revision of the original...
2K
