Discuss Condensation In Bathroom With No Window - Best Extractor Solution? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Sure - but if the problem is fixed, i'll stop there.Flexi vent is 100% rubbish on anything other than runs that are short or need to go around corners
concorde was shaped as it was for airflow reasons
We appreciate your replies/updatesSure - but if the problem is fixed, i'll stop there.
if it comes back with a vengance in the colder months as you rightly pointed out - i'd swap the ducting then I guess.
I thought you said the red lines were marking where the vent runs ????????
extractor fan swapped over to a Vent Axia Lo Carbon Quadra, Centrifigual type extractor fan.
At maximum speed setting (220 m3 per hour), it is preventing moisture in the room, but by god is it loud, its deafening when you're in the room at round 50decibels.
You haven't been using it for long enough to draw any conclusions - and remember its a warm dry time of year
20 minutes minimum for the over run timer IMHO
Yes, i'll update shortly doing the work now - we've added an access hatch for the ACM 125T Vent axia.Fwiw concealing an inline fan above the ceiling needs access
thanks - don't have any where near the width for that. So notching out it is!204 x 60 is 5” equivalent
220 x 90 is 6” equivalent.
Reply to Condensation In Bathroom With No Window - Best Extractor Solution? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
